Thread: Swirl flaps - are they worth it?
Page 7 of 8 FirstFirst ... 5678 LastLast
Results 61 to 70 of 74
  1. Re: Swirl flaps - are they worth it?
    #61
    Dec 2015
    Southend, UK
    Working from comments on this and other forums I took the plunge the other day and had the swirl flaps/ runners disconnected and mapped out on mine as preventative maintenance. The choice was a no brainer as I was having a remap and EGR delete anyway and the provider (Black Code) agreed to map out the swirl flaps inside the same price. I had an MOT done directly after the remapping to check the emissions are still safely within limits.
  2. Re: Swirl flaps - are they worth it?
    #62
    Aug 2016
    Gateshead, UK
    I've just been reading through a few swirl flap threads here, mainly to find-out if they can be removed completely.
    FWIW, my BMW 330d had the flaps removed by a previous owner and is de-catted and de-EGR'd. A few weeks ago, at 143k mls, it sailed through the MOT with all the emissions at the very lowest end of the parameters. Over nearly 40k mls, the car has averaged 40.7mpg. Also, as a bonus, since the EGR removal the oil stays clean for several thousand miles.
  3. Re: Swirl flaps - are they worth it?
    #63
    Dec 2015
    Southend, UK
    They aren't needed for the MOT and just cause expense when they go wrong. Simply removing them will bring up the engine fault light + codes so they have to be mapped out (same as the EGR, which i had done at the same time). The electrical connection to the flap motors can then be disconnected and tied up out of the way. My fuel economy improved significantly and the car is better to drive. If anyone in the future wants to reconnect them then they are are all still there but just unused
  4. Re: Swirl flaps - are they worth it?
    #64
    Sep 2016
    windsor
    Hi all i had same issue with the intake manifold swirl flaps. I have done my resarch and found the website with repair kits(new swirl flaps etc) the also include repair manual. Im not a mechanic but i have complete the job replacing flaps on both Banks in 5 hours.
    IF somone is interested they call
    manifoldkitsuk.co.uk
    Complete repair kit cost me £125 with new gaskets so happy days
  5. Re: Swirl flaps - are they worth it?
    #65
    Sep 2016
    windsor
    Sorry they call manifoldskitsuk.co.uk
  6. Re: Swirl flaps - are they worth it?
    #66
    Jul 2015
    Staffs
    46 Post(s)
    Quote Originally Posted by Not_Anumber View Post
    Did you physically remove the flaps, or just leave them in situ?
    Ian
    A4 B6 Avant Nogaro Blue
  7. Re: Swirl flaps - are they worth it?
    #67
    Dec 2015
    Southend, UK
    I left them in situ as their default position when powered down is open. With these and the EGR mapped out my fuel economy has improved. Whilst i used to average around 43 mpg for my regular motorway commute this has improved to 50.
  8. Re: Swirl flaps - are they worth it?
    #68
    Jul 2015
    Staffs
    46 Post(s)
    I was just pondering if even in the open position they cause a restriction in air flow?
    Ian
  9. Re: Swirl flaps - are they worth it?
    #69
    Dec 2015
    Southend, UK
    Id say no more that them being in the open position during normal running as Im presuming they were designed not to be noticeably restrictive. It might be worth someone experimenting to see if physical removal of the flaps might provide a marginal improvement, though this might be too small to measure.
  10. Re: Swirl flaps - are they worth it?
    #70
    Dec 2014
    Mumbai, India
    I had mine mapped out by my tuner as I kept getting the annoying check light. Run approx 10,000kms after that and found no issues with the car after that.
    Jignesh
    2009 Audi A6/C6 3.0 tdi quattro remapped stage 2 with full Miltek catback exhaust & K& N filter
  1. Please Help Mud Flaps For a Touareg Altitude
    By bryn7 in forum Touareg
    Last Post: 12-01-2011, 07:01 PM
  2. Audi a8 2003 Current gearshift program problem
    By eints77 in forum VCDS - Help Requests
    Last Post: 20-07-2010, 02:58 PM
  3. Please Help Is it worth it?
    By lew247 in forum Octavia
    Last Post: 03-06-2010, 04:59 PM
  4. Flaps on, or, flaps off.
    By roxyland in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 06-03-2010, 11:15 PM
  5. Whats My Dads Car Worth?
    By SHAZA4 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 18-04-2008, 03:47 PM
