Thread: Wheel bolts coming loose !!!!
Results 1 to 10 of 18
  1. Question Wheel bolts coming loose !!!!
    Oct 2009
    Hampshire
    Hi everyone.
    So still loving the CC after almost a year now in almost every respect.
    However just checking the tyre pressures this afternoon and I notice one of the front wheel bolts missing. So just thought i'd take the caps off and check the others and they were all loose i.e. I could undo them with my fingers. So checked the other wheels and the other front wheel bolts were all loose as well, but the back ones all nice and tight. I had noticed a slight vibration at speed in the weeks before but put this down to balancing and put it on my list of things to get round to. Thinking about it, it's quite scary as I'm up and down the motorway everyday and the thought of a wheel flying off is not a nice one.
    The car did have it's first service 2 months (1,000 miles) ago at a VW garage and I did ask them to rotate the wheels so I'm beginning to think they just didn't tighten the front ones up? In fact I think the remaining bolts may have only stayed put due to the plastic caps encouraging them to stop working loose any further, but that's like holding back a dam with your thumb.
    So, can anyone shed any light on the above (I've never had bolts come loose on any car in the last 20 years) and if there could be any other explanation other than forgeting to tighten them up?
    If not, has anyone any views on what I should ask for when I call them on Tuesday to raise this issue? I obviously need a new bolt but am I reasonable asking for a discount/refund on the service or more?
    Is it best to speak to the service dept or ask for the boss or even go straight to VW UK head office?
    Many thanks for your thoughts.
    Shadow CC
  2. Re: Wheel bolts coming loose !!!!
    130 Post(s)
    1972 Post(s)
    I have never known wheel bolts to just come loose except on wheels that have been recently re-furbished where the paint can come off under the bolt and cause the bolt to come loose. What probably happened is that they put the wheels back on lightly with an air gun and then forgot to tighten them up with a torque wrench on the floor. It is so easy for a mechanic to do this, all that needs to happen is for him to be doing the job, get called away for something or for tea/dinner break to happen just then and that’s it, bolts left loose.
  3. Re: Wheel bolts coming loose !!!!
    DSG4ME Guest
    Generally the bolts are designed to use centrefugal force to tighten up them up automatically, of course this doesn't always work, especially if it's been left loose enough to not bite the wheel and take the vibration factor out.
  4. Re: Wheel bolts coming loose !!!!
    Rutland
    Hmmm, always put the torque wrench on the wheel bolts again 50-100 miles after I've refitted them. Perhaps I'd better spread the net.
    Passat Estate GT 16 190/295 DSG Sand Gold/Espresso, Premium LEDs, Area View, DA Pack Plus, Park Assist, XDS, Boot divider, Olive Ash.
    TDI history, all saloons: CC 59 140/236 GT, Passat 06 140/236 Sport, A6 SE 2000 110/173, A4 SE 1995 90/149, 80 1992 90/134, plus SWMBO's 2000 A3 SE 90/155 hatch.
    1979 Alfasud 4 door 1.5 in Verde Pino. 105 bhp Green Cloverleaf engine .
  5. Re: Wheel bolts coming loose !!!!
    Dec 2009
    Waterlooville U.K.
    13 Post(s)
    Crasher's comment about paint under the head of the bolt is very valid . I remember many years ago at a VWdub "meet" that some people were saying that someone had gone around in the night and had loosened a lot of Beetle wheel nuts. At that time it was quite the "in thing" to paint steel wheels with Hematite paint . This paint is similar to a resin substance and when it cures it shrinks. It transpired that the cause of the problem was the paint under the bolt heads either shrinking or breaking up that caused the bolts to become loose.
    Skoda Octavia II SE 1.9PD TDI
  6. Re: Wheel bolts coming loose !!!!
    Oct 2009
    Hampshire
    I'm with crasher in that the likely cause is probably a tea break as my new ish CC has never and hopefully never will see a tin of hammerite.
    Time for a call to VW to see their perspective on returning my car to me in a more dangerous state than I delivered it to them in.
  7. Re: Wheel bolts coming loose !!!!
    Oct 2009
    Hampshire
    Just to close the story, I called VW, the boss called me back in 2 mins. I took the car in this morning, they checked it over for any additional damage and refunded the cost of my service and said sorry.
    These things happen and we all forget to do stuff (even dangerous stuff) but I can't fault the way VW dealt with it, with not a hint of defensivness and a genuine desire to sort it and quickly.
    Fair enough. Matter closed. Faith in VW back to normal, although I will be checking the bolts after the next few services ;-)
    Shadow
  8. Re: Wheel bolts coming loose !!!!
    Feb 2009
    Glasgow UK
    Nice result there shadow
    Great news that VW stepped up to the plate and dealt with it. Too many dealerships these day are trying to run n hide when sumthin like this pops up
  9. Re: Wheel bolts coming loose !!!!
    Dec 2009
    Waterlooville U.K.
    13 Post(s)
    Would they have "stepped up to the plate" if the car was a write-off because a wheel fell off ?
  10. Re: Wheel bolts coming loose !!!!
    Feb 2009
    Glasgow UK
    you're probably right there vwcab. As you say, easy to step up when its not a major problem and relatively inexpensive to fix!
    Having said that, I've had some major troubles with my A6 ( as posted in other threads ) and Audi have been great and really stepped up to the plate.....probably cost them ££££ to repair / maintain my car under a combo of warranty and goodwill.
    A good friend of mine has an X3 ( not my cup of tea ) and has 41k on the clock 4 years old and BAM turbo blown ( turns out to be a common fault ) an gets it replaced at a cost of £3000 or so all in and has to stump up £700. Not too terrible, although you wouldn't expect a turbo to go with that low mileage with the car being loved n looked after.
    Unfortunately though, he's his own worst enemy with the service peeps and when the problem re occurred he was shouting / screaming and name calling BIG TIME......The end result??
    BMW told him to take his car away and go somewhere else, They had also told BMW UK not to make any more goodwill payments to his car.
    The dealership had the last laugh.....Cost him quite a few pennies to have his say!
    I always, always get the service personnel on my side and make it my business to get to know them and the parts people personally. Also drop a bottle of wine / case of beer in at Xmas etc etc and boy do they look after me!!
    I've had warranty / goodwill where many others have not, discounted prices on parts, oil for free, always a couretsy car no matter when i go in and have had some crackers too, some with 300 miles on the clock.
    It really does pay to get to know these guys and look after them
  1. Knocking Noise coming from passenger side front wheel..!! Help
    By Louis 73 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 26-03-2021, 02:26 PM
  2. Clicking Sparking Noise coming from Drivers side wheel arch.
    By afghandaz in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 21-05-2010, 08:24 PM
  3. renew wheel bearings without joint pain
    By caldirun in forum Passat - B5 Forum - 1997 -2005
    Last Post: 06-12-2009, 10:10 AM
  4. Question Golf Mk4 GT TDI Rear Wheel Bearing
    By tommi in forum Golf MK4 - 1999 - 2004
    Last Post: 25-05-2009, 08:21 PM
  5. Do I need new wheel bolts ?
    By martinrhodes in forum Audi A6 - C4 Forum - 1994 - 1997
    Last Post: 18-04-2007, 08:26 PM
