Thread: uneven tick over
Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
  1. Re: uneven tick over
    Jul 2010
    crewe
    how much do you know about stero systems? my audi is fitted with audi single cd concert type. Can i fit an of the shelf stero to it cause someone at work mentioned about can wires and how it messes up elec system. Im after fitting ipod connection into glove box and have seen an alpine unit that has lead coming from the back of stero which can be placed in glove box, any ideas?
  2. Re: uneven tick over
    tony-1977 Guest
    Quote Originally Posted by gav20 View Post
    Depends on the connection type on the back of the new stereo you are getting. You might need an adapter and fascia plate (Halfords?) to connect it up and fit properly
    I have heard someone saying that after-market stereo's can interfere with the electrics. Not sureif there's any truth in this? Maybe someone else can help?
  3. Re: uneven tick over
    Oct 2009
    Eyemouth UK
    Just a quick heads up bud, if you are heading to quick fit for your service make sure they drain the oil from your engine and not your gearbox.
    I know this sounds like a really daft point but a couple of days after having my a4 avant serviced there the gearbox went. Posted on here for advice as to where to replace the gearbox and found another owner in exactly the same position.
    When the garage checked my gearbox there was no oil in it and no obvious signs of a leak. However to prove this was nigh on impossible and I ended up forking out over £1000 for a replacement.
    £45 may seem like a big difference but pales in comparison to a bill for over £1000 to fix shoddy workmanship.
    Just a friendly bit of advice, realise not all garages will be as incompetent as my local Quick fit but better to be forewarned.
    Good luck with the fault.
  4. Re: uneven tick over
    tony-1977 Guest
    Quote Originally Posted by paulpingu View Post
    On another note re Quick Fit. A few years ago, me and a mate fixed up my car's brakes and they were faultless. We took it to QF for one of their "free brake checks". From a distance, we watched them put brake fluid on the calipers and discs, then had a poke arouind for about 5 mins, they then approached us and said it was leaking and needed £400 worth of work! Wished I'd had my phone to hand to take a vid...
  1. Tick, tick, tick.....................
    By HHGTTG in forum Golf MK6 - 2009 - 2013
    Last Post: 12-06-2010, 10:02 PM
  2. Fluff tick over
    By Kleinxv in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 16-06-2009, 08:01 PM
  3. Evap Valve .... Tick...Tick....Tick
    By J..M in forum Passat - B5 Forum - 1997 -2005
    Last Post: 19-04-2008, 05:20 PM
  4. Indicator 'tick tick' noise
    By avaghela in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 28-07-2007, 10:21 PM
  5. lumpt tick over passat tdi
    By patsy in forum Chat - Completely Off Topic
    Last Post: 10-01-2007, 09:55 AM
