Thread: 1.8T cam locking
  1. 1.8T cam locking
    Jul 2010
    Brighton
    Can anyone tell me if there is a cam locking tool for the AWT 1.8T engine i'm looking at doing the cam belt, but i can't find the right tools anywhere
  2. Re: 1.8T cam locking
    May 2007
    knee deep in clunge
    14 Post(s)
    there are no locking tools but there are marks for tdc on the rocker cover and cam pulley and also the flywheel and the crank pulley
  3. Re: 1.8T cam locking
    Jul 2010
    Brighton
    Quote Originally Posted by a8 tech View Post
    So to ask a silly question, but how do you lock it off then so that nothing moves?
  4. Re: 1.8T cam locking
    May 2007
    knee deep in clunge
    14 Post(s)
    you don't, time the engine up with the marks then r+i the belt and tension it then rotate two full crank revolutions then check the belt tension and the timing marks.
    If the pulley moves when fitting the belt use a holder to realign
  5. Re: 1.8T cam locking
    Jul 2010
    Brighton
    ah right, ok at least i know now its not me going mad and i can get on with this job tomorrow got all the parts from work, the complete SKF kit inc damper only cost me £32 with my discount and i've got an SKF water pump for £7
    thanks for the advise a8 tech
  6. Re: 1.8T cam locking
    May 2007
    knee deep in clunge
    14 Post(s)
    Attachment 9017
    Attachment 9018
    Attachment 9019
    Attachment 9020
    Attachment 9021
    If the toothed belt tensioning element is fully out, it must in its installed position, be pushed back with tensioning roller. This process can take up to 5 minutes. Too much force when pressing together can damage the tensioning roller.
    Turn eccentric anticlockwise using pin wrench -3387- (lug -A- of eccentric must not be bent), until the locking plate -T10008- is not under tension and can be pulled out.
    Turn eccentric clockwise in -direction of arrow- until a drill -2- dimension -a- can be pulled out between tensioning lever and tensioner housing.
    Specification dimension -a-: 8 mm
    Hold tensioning roller in this position and tighten tensioning roller securing nut -1- to 27 Nm.
    Tensioning roller from 08.00 (must be adjusted)
    Check, using a drill -2- the dimension -a- between tensioning lever and housing.
    Specification dimension -a-: 6...10 mm
    If dimension -a- is not achieved:
    Release tension on toothed belt
  1. B5 A4 Central Locking FAQ
    By ini in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 01-09-2015, 11:46 AM
  2. Please Help Octavia- Central locking keeps locking.
    By Mawb in forum Octavia
    Last Post: 27-09-2013, 02:53 PM
  3. Question 2.5 tdi afb engine crankshaft pulley locking pin location
    By rsmtechnicians in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 04-02-2010, 10:49 AM
  4. Guide S4/A4 V6 Cambelt
    By spellmaster in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 05-10-2009, 05:23 PM
  5. Question 1998 Passat 1.8T 20V Cam Belt, How do I know whether I need a change?
    By damjee in forum Passat - B5 Forum - 1997 -2005
    Last Post: 20-07-2008, 07:28 AM
