Hi - I have an R-Reg 1.6. The starter motor is not working and I need to figure-out why.
There is a 2-way connector mounted on the top of the starter motor with only 1 position used. The offside wire disappears into a harness and the nearside wire is sheathed in tubing and disappears under the battery tray. There also appears to be another wire at the nearside end of the starter motor/solenoid. I am guessing that this last wire is the wire from the ignition switch to the solenoid. Am I right? What is the wire in the 2-way connector?
Thanks for any help.
Cheers,
Ian
