Thread: T5 Turbo hose blowing off
  1. T5 Turbo hose blowing off
    Feb 2010
    Laurencekirk Scotland
    Have a 04 2.5 T5 that has had the large turbo hose replaced along with the clip. It blew it off again today under a bit of load but nothing too much. Just wondering if this is a common thing and are the clips really any good. Did manage to refit hose in about 5 mins but really don't want the wife having to do this. Any comments most welcome. Cheers
  2. Re: T5 Turbo hose blowing off
    Nov 2008
    Cramlington,Northumberland
    20 Post(s)
    It is common on T5, the clip and Lugs on the Hose wear. But, if the hose and clip have been replaced together i wouldn`t expect it to blow off. Is everything fitted correctly? I would have thought if there was a Turbo Overboost, it would go into Limp Mode and not blow a hose. Check for excess wear were the clip sits in the housing.
    Alan.
    VW T6 150 DSG Camper £££
  3. Re: T5 Turbo hose blowing off
    Feb 2010
    Thanks for that.
    I will have to take it back to the garage to get them to check it in front of me. Wife did it yesterday but guy who checked it did not give her much confidence that her knew very much about it. Would this happening cause any damage to either the turbo of engine?
    Allan
  4. Re: T5 Turbo hose blowing off
    Nov 2008
    20 Post(s)
    No damage, just a sudden loss of power...which isn`t good in some situations! Are you sure clip and hose renewed together, or is it a new hose and the original clip?
    Alan.
  5. Re: T5 Turbo hose blowing off
    Feb 2010
    Yes both clips and hose replaced at the same time. It's the bottom part of the hose that comes out, possible worn plastic housing that it goes into according to the garage. We have put a jubilee clip over the retaining clip to keep it firmly in place. Will have to see how that goes. Will let you know how it goes as I don't expect the plastic housing will be pennies!!
  6. Re: T5 Turbo hose blowing off
    Nov 2008
    20 Post(s)
    Yeah, possibly be that if the hose still blows off.
    Alan.
  7. Talking Re: T5 Turbo hose blowing off
    Feb 2010
    Hose has stayed on since fitting jubilee clip. It looks like problem solved. Might even fit one to the top end of the hose as an added precaution.
  1. Please Help Turbo failure again-help please!!!!!!!
    By Tyanu888 in forum Golf MK5 - 2004 - 2009
    Last Post: 17-03-2011, 09:18 PM
  2. Split Turbo Hose
    By pass&golf_tdi in forum Passat - B5 Forum - 1997 -2005
    Last Post: 21-02-2010, 08:31 PM
  3. "How To" The FAQ & How To Thread
    By Ben in forum General
  4. MK3 TDI turbo dying... remap or hybrid turbo?
    By leoninanegg in forum Golf MK3 - 1993 - 1999
    Last Post: 15-06-2007, 08:48 PM
  5. Passat 130Tdi turbo problems
    By Jon Tallis in forum Archive posts
    Last Post: 05-06-2007, 07:52 AM
